thanks a lot for adding the colors and support for multi cars on one user!
do you recommande to use a separate user for the API or the same as your main user will do?
Now I can see my 3 smart #1 with one user!
chriscat
Thanks, I think this already helps me to understand the problem. I'll try to implement a possible way to fix this behaviour. It's obviously a permission thing.
I'll try to implement a possible fix and will come back to you if that's ok (for testing).
i suspect something like that but you might need a proxy to look at it happening when you change car.
I could share one car with you so you can try. I am moving house. I can’t help with a proxy for now.
in addition to support for multiple cars, it could also improve the reliability if we understand this authorisation.
I think I needed to login again in hello smart for a user to work via API. When the user hasn’t been used for a little while . but it takes a while to reproduce. It could be related
Of course I can help with testing the possible solution when you think you get one. That would make the whole thing easier than one user per car
Could you maybe debug it a little, put your credentials directly in the script and check it with different vins? Basically it's just one api call inside the getCarInfo() method. The result of it is already logged on the console (huge json response). I only have one car so I can't double check.
The other day, I already tried everything I could think of. But today the test was even simpler:
1. The widget works for Car A, I confirm it by going in scriptable and run it.
2. I go to hello smart, which is showing Car A and I change to look at Car B
3. I go back to scriptable and run the same script for Car A and it fails with following consol logs
2023-11-18 14:09:09: Found apiAccessToken.
2023-11-18 14:09:09: Signing api request with hmac *********
2023-11-18 14:09:10: status code: 200
2023-11-18 14:09:10: {"data":null,"code":"8160","httpStatus":"OK","success":false,"hint":null,"sessionId":"***********","message":"Currently no permission to operate"}
4. I go back to hello smart and switch to car A
5. The widget works again perfectly
Noch eine Idee: Irgendwelche besonderen Sonderzeichen im Passwort? Zum Beispiel ein , oder ein ;
sorry I forgot I had to change my script too because of special characters in the password! I should have shared it and forgot:
see the change I made here:
see if adding those
encodeURIComponent(userName) and encodeURIComponent(password) fixes your issue. My API user password was starting with a '&' and it didn't like that at all.
chriscat
Thanks for verification. The temperature is from the inside of the car. It changes here all the time, especially at night (7 degrees last night). If you start the air condition from the app, it should definetly change. That's one reason why I put it there. In a future update, I was thinking about starting the air condition from within the widget (bigger size).
I see, it will be handy in winter.
I made it work for 2 cars with this small change https://github.com/marco79cgn/ios-scriptable-widgets/pull/3
I had to use 2 different users. A given user can access only the latest car that was accessed in the App.
I also noticed that if a user wasn't used in too long, I have to login with it in the Hello Smart app to make the widget work. Did you notice the same thing with a dedicated API user? needing to logon with hello smart if you haven't used it in too long.
Next step: I will change the image for each car to be able to recognise them. 2 are blacks, and I will mirror one to make it the UK one
Also, with the address format in France, number would come first. but I'm not bothered by it.
Alles anzeigenchriscat
And now it makes perfectly sense. I forgot to remove line 73 of the script where I already tested successfully to lock/unlock the car! That's why it makes noises when you have it set up on your phone. It was hard coded to always lock the car. Controlling the car only works at all if the device is connected via Bluetooth to your car and the digital key is active. That's why it didn't happen on your iPad. Please remove line 73 of the script or download the complete updated script again from github.
An alle, die das Skript bereits installiert haben:
Bitte in Scriptable Zeile 73 löschen. Sorry dafür!const lockIt = await lockCar(credentials.apiAccessToken);
Alternativ das komplette Skript neu bei Github runterladen.
Die Steuerung für's Auto will ich - wenn überhaupt - erst später einbauen. Das Problem ist, dass der Smart ständig den Digital Key verliert (zumindest bei mir), so dass das nicht zuverlässig funktioniert. So viele Bugs bei Smart. Echt frustrierend!
Indeed. All makes perfect sense. I suppose it’s also why I got the message my 12V battery was low and I should start the car. I never had such a message from hello smart before.
battery draining by locking the car every few minutes and maintaining the Bluetooth connection from next room.
All seems to work now. I even tested successfully the location today.
Thank you
Is the temperature useful for you? It never gets updated for me. It stayed tonight at 24 and update to 17 only when I started the car
Sadly I had to remove the widget from my iPhone as I kept hearing the car every 10 minutes or so. the sound the car usually makes when we lock it.
After stopping the widget the sounds stopped. After adding it back on my iPhone one hour later, the sound came back immediately.
The weirdest part is that all along the widget was on iPad too and there is no problem there
Ah, my bad, Sorry. Actually multiple users are not supported yet. Only one user with multiple cars.
This is because I store the credentials and tokens for the user inside a file in iCloud Drive in order to cache them. This way I can reuse the tokens as long as possible without having to log in again.
Please do the following:
- delete all your Smart widgets from the home screen (to stop them running automatically every few minutes)
- go to your iCloud Drive Scriptable folder (e.g. in the Files app) and delete the file smart-credentials.json
- setup one script/widget again and see if it works (it should!)
After that you can set up another car but it has to be the same user! All scripts/widgets use the same user tokens as of now.
I wonder if with this method it means we don't have to fear to setup also on iPad and Macbook in addition to iPhone, with same credentials. Because iCloud sync the file between devices.
When you said "setup one script/widget". Do you mean one script per widget? I like it better if I plan to re-use it on more devices.
I can get only one working at a time. one or the other.
After a few tries, it seems it's the lastest car I used on the app. it would mean it's impossible to avoid this issue. I would be able to get only the one I used last in the app for each user
Basically you don't need one user per car in order to setup multiple widgets as long as your single user has access to all cars.
So there are two options for you (I'd prefer the first):
- leave the script as it is (from github) and set up the parameters only in the widget configuration: username;password;vin (works as long as there is no semicolon in your password)
- set up the script multiple times in Scriptable (with different names) and hard code your user, pass and vin in each script (line 21-23) - in this case, leave the widget params empty in the configuration!
I tried with both solutions. Neither worked. I suspect my users are blocked but I still can connect into the app
Using twice the same user, I thought it might explain why i had credentials error. You said one account can connect only once so I tried with 2.
It worked for the first car. But when I added a 2nd car, it never worked and the 1st started failing too.
I’ll give it a couple of hours and see again. Maybe just a temporary block because I logon onto the app to share the cars.
When I got the car in late April, it worked for a few months without a problem. But yes, obviously they broke this functionality somehow. Really frustrating, so many bugs!
If you set up the widget on your homescreen by just using the parameters, you can setup multiple widgets simply by using different vins - no need to touch the script at all. So it's both more secure and more flexible.
Thanks. actually the trick was just to use the VIN for the 2nd car. I was looking for an index.
I created a 2nd API user so that I could get 2 widgets at the same times.
Do we have to wait for a while after we connected in the app with that user to accept the sharing? I lost access also to the 1st one which worked before.
