Beiträge von chriscat
    Do you know when the official Hello# will be available in the app store?
    Apple requests Smart approval if we keep the app the way it looks today.
    Our contacts at smart are all for it but they have been looking at it with their legal team for weeks. I just hope they will answer before most of us will have to choose our next car
    ABRP’s CEO response:
    We issue quite a few HA API keys, but it would be much better if somebody wrote an ABRP plugin for HA so that we could share the same API key for everyone (and just have user/vehicle tokens for each user).
    So nothing is stopping us on that side.
    Nice!
    Now I’m tempted to start the work on an ABRP integration, universal for all cars.
    https://github.com/martijnpoppen/com.abetterrouteplanner
    This is the Sourcecode site, i think it is similar to HA
    I don’t know Homey. I see this repo is requesting the user to provide the api key
    com.abetterrouteplanner/lib/abrp/abrpOAuth2Client.js at main · martijnpoppen/com.abetterrouteplanner
    A Homey app for ABRP. Contribute to martijnpoppen/com.abetterrouteplanner development by creating an account on GitHub.
    github.com
    Code
    api_key: Homey.env.CLIENT_SECRET
     this.api_key = params.api_key;
    I asked directly ABRP their position on HA-like projects. They answered quickly usually.
    With this example above I suppose the hardest is already shared: a JavaScript library
    If ABRP gives api key to each user, we could make it work. I am just surprised they would answer every email but why not?
    Für den Homey Smarthome hat jemand schon eine App programmiert, da logt man sich mit den ABRP Zugangsdaten ein und dann wählt man sein Auto aus eine Liste aus, das Problem dabei ist, ich bekomme die Daten von Smart nicht in Homey.
    Deswegen denke ich es fehlt nur die richtige Programmierung.
    Aber wie gesagt ich kenne mich nicht aus
    Can you see the source code? Or is it a paid service on a website?
    For a paid website they could get an API Key without the whole world seeing it.
    In HA you can’t setup anything without having all the passwords and api keys yourself.
    I’ll ask them and share the response when ABRP answers me.
    Es tut mir leid, ich werde den Text unten nicht ins Deutsche übersetzen, weil er zu technisch für Google Translate ist und ich kein Deutsch spreche.
    ABRP Live API was simple to use. See the documentation here:
    Iternio Telemetry API
    The Iternio Telemetry API allows your application to send data to A Better Routeplanner for use in driving with live data, and helping us improve our car…
    documenter.getpostman.com
    I have been playing with it for the past 2 weeks for Hello #
    From my exchange with Iterno, their OAuth API is under reconstruction.
    it would make it smooth for users, to generate user/vehicle token. For the moment they recommend using the “Generic” live data method in ABRP. Where each user clicks on generate token and copy/past it in the app making use of it (hello # or HA)
    The obstacle: for hello # they provided an API Key, without which all of this is blocked. I don’t see how they would give each user an API Key.
    I only hope their new future OAuth API is an answer to this need we have for individual projects in HA and such.
    I see you use
    Ich sehe, dass du es benutzt
    Code
                retval["charging_power"] = ValueWithUnit(
                    float(evStatus["chargeUAct"]) * float(evStatus["dcChargeIAct"]) * -1, "W"
    in Hello # we used this logic:
    in Hello # haben wir diese Logik verwendet:
    6751W is the same value shown by the car, not 3642W. I don't think you should use dcChargeIAct. Nor do I know what it is when not CCS charging
    EDIT: I think dcChargeIAct is for 400V values directly to the battery. So it would take the loss into account, but we don't have the voltage.
    29.1 * 232 = 6751W
    3642W / 232 * 400 = 6279.31 W
    without loss: 6.75 kW, with loss 6.28 kW
    but I don't think it's 400V precisely. I wouldn't use that calculation
    6751 W ist der gleiche Wert, den das Auto anzeigt, nicht 3642 W. Ich glaube nicht, dass Sie dcChargeIAct verwenden sollten. Ich weiß auch nicht, was es ist, wenn kein CCS-Ladevorgang erfolgt
    EDIT: Ich denke, dcChargeIAct ist für 400-V-Werte direkt an der Batterie. Es würde also den Verlust berücksichtigen, aber wir haben nicht die Spannung.
    For pre-conditioning control entity, I never found it in HA. I remember seeing an error that the entity could not be loaded and when I looked at GitHub I saw your message saying it was not stable. So I just assumed you knew it didn't load.
    When I search for entities without area, I don't find it either.
    I just found it under a different name when searching for entities.... awesome! I'll test it
    Was die Vorkonditionierungskontrolleinheit betrifft, habe ich sie in HA nie gefunden. Ich erinnere mich an einen Fehler, der besagte, dass die Entität nicht geladen werden konnte, und als ich mir GitHub ansah, sah ich Ihre Meldung, dass sie nicht stabil sei. Daher habe ich einfach angenommen, dass Sie wussten, dass es nicht geladen wurde.
    Wenn ich nach Entitäten ohne Fläche suche, finde ich sie auch nicht.
    Ich habe es gerade unter einem anderen Namen gefunden, als ich nach Entitäten gesucht habe.... großartig! Ich werde es testen
    Es sollten eigentlich seit Version 0.3.0 sowohl die Vorklimatisierung als auch der DeviceTracker als Entität zur Verfügung stehen. Aktuell habe ich nicht sonderlich viel Zeit daran zu entwickeln, aber ich habe mit Sitz-/ und Lenkradheizung Ansteuerung begonnen.
    Automatisch übersetzen:
    soll die Vorkonditionierung funktionieren? Ich dachte, es wäre noch nicht fertig. Ich kann kein Steuerelement sehen und habe beim Start nur eine Fehlermeldung gesehen. Ich kann mitteilen, ob es funktionieren soll.
    Bin ich auch der Einzige, bei dem die falsche Ladeleistung angezeigt wird?
    Die Berechnung ist korrekt, wenn ich dem Python-Code glaube, aber 29,1 * 232 = 6751 W, nicht 3642 W, wie ich in der letzten Stunde auf meinem HA sehen kann:
    English original:
    is the preconditioning supposed to work? I thought it was not ready. I can't see any control and only saw error message on startup. I can share if it's supposed to work.
    also am I the only one with wrong charge power showing?
    The calculation is correct if I believe the Python code, but 29.1 * 232 = 6751W, not 3642W as I can see for the past hour on my HA:
    Ich habe es jetzt ein paar mal getestet wenn ich auf der Klimatisierungsseite auf den untersten Punkt „Vorklimatisierung beenden“ klicke baut sich tatsächlich die Verbindung wieder auf!
    I have now tested it a few times when I click on the bottom item "End pre-air conditioning" on the air conditioning page, the connection actually rebuilds itself!
    When Vodafone UK 4G is fixed around my house I’ll try with turning off the seat heating even if it’s off. It should have the same effect and would not consume battery.
    Can you try that before me? Or is it only possible to turn off if it’s on in iobroker?
    Wenn Vodafone UK 4G in meinem Haus installiert ist, versuche ich, die Sitzheizung auszuschalten, auch wenn sie ausgeschaltet ist. Es sollte den gleichen Effekt haben und keine Batterie verbrauchen.
    Kannst du das vor mir versuchen? Oder ist das Ausschalten nur möglich, wenn es in iobroker aktiviert ist?
    Alles was man mit der Hello # App machen kann sollte man mit dem Smart Home Gedöns (ich kenn mich da fast null aus) auch machbar sein, denn beide nutzen ja inoffiziell die undokumentierte API von Smart.
    Automatische Übersetzung:
    Tatsächlich funktioniert das Schließen des Autos mit demselben API-Befehl wie gewohnt, auch wenn es bereits geschlossen ist.
    Das Hauptproblem bei dieser Methode besteht darin, dass sie den Alarm auslöst. Befindet sich jemand im Auto (und wartet auf Schnellladung), ertönt der Alarm.
    Und seien Sie sich bewusst, dass ich es nicht getestet habe, während jemand gefahren ist. Normalerweise lehnt das Auto jeden Befehl ab, wenn es fährt.
    Ich versuche immer noch, einen anderen Befehl zu finden, der diese Art des Aufweckens des Autos ersetzt.
    Hallo # ist in der Pause, da ich diese Woche nichts testen kann. 4G ist bei mir zu Hause ausgefallen und selbst wenn das WLAN gut funktioniert, wird offenbar kein WLAN verwendet, um Aktualisierungen an die API zu senden.
    Ich habe die ABRP-API getestet und sie funktioniert wie ein Zauber. Ich warte nur darauf, dass die Auto-API wieder Updates erhält, wenn Vodafone UK meinen Bereich repariert....
    original:
    indeed, closing the car with the same API command as usual works even if it's already closed.
    The main issue with this method is that it turns on the alarm. If someone is in the car (waiting for fast charging) the alarm will ring.
    And be aware that I didn't test it when someone is driving. Usually the car rejects any command when it is running.
    I'm still trying to find another command to replace this way of waking up the car.
    Hello # is on pause because I can't test anything this week. 4G is down around my house and apparently even if wifi is working well it doesn't use wifi to send updates to the API.
    I tested ABRP API and it's working like a charm, I just wait for the car API to get updates again when Vodafone UK will fix my area....
    chriscat I've got a question concerning the amount of mobile data that is used in 'common use' of the app. Can you say something of the response size that you get from the server per update?
    Just wondering since the Hello Smart app uses quite some data (ca 1.3GB since Dec 2023) despite only occasional using it, mostly during weekend.
    In order to make Hello #, I inspected the traffic in details from Hello Smart.
    It was clearly unreasonable. It made my work harder because it was a stunami of requests.
    In hello # we use the same requests, but less often.
    The API calls are returning the small JSON files you can see in Raw Data Viewer. I can’t imagine it would make 1.8GB of data
    When you start hello smart they download each time their assets from Adobe. I could be wrong as it seems to be in a package including everything and I was not interested by that part.
    Just a guess, but I suspect their reliance on adobe is a great contributor to the slowness and unresponsiveness
    Um Hello # zu erstellen, habe ich den Datenverkehr von Hello Smart im Detail untersucht.
    Es war eindeutig unvernünftig. Es machte meine Arbeit schwieriger, weil es eine Flut von Anfragen gab.
    In hello # verwenden wir dieselben Anfragen, jedoch seltener.
    Die API-Aufrufe geben die kleinen JSON-Dateien zurück, die Sie im Raw Data Viewer sehen können. Ich kann mir nicht vorstellen, dass es 1,8 GB Daten ergeben würde
    Wenn Sie Hello Smart starten, laden sie jedes Mal ihre Assets von Adobe herunter. Ich könnte mich irren, da es sich offenbar um ein Paket handelt, in dem alles enthalten ist, und mich dieser Teil nicht interessiert hat.
    Nur eine Vermutung, aber ich vermute, dass ihre Abhängigkeit von Adobe einen großen Anteil an der Langsamkeit und mangelnden Reaktionsfähigkeit hat
